PI Swap all done
SFC.Kill
55
Parker Ford, PA
Finally done with the PI swap. She started right up. Sounds alot smoother, Throttle is more responsive. Will let you guys know how test drive goes. Thank to everyone one who helped me with the colored link on the timing chain issue.
sounds great, just fixed mine up tonight, i did the swap last weekend, but it turns out that i had one cam 180 degrees off... opps, that would explain the rough idle. I was surprised it ran at all...
She pulls like a mo-trucker, P&P PI heads ftw :)
moving the crank around during install. I held the position on the cam to gear by zip tieing it. I forgot the final check of making sure the two cams where synced together. It was late in the night, i spent a lot of time getting the header bolts back on (with long tubes). Being 180 degrees off is "correct" but in the wrong stroke. That's why the compression testing read correctly. Its funny to look back on it now, close one.
