PI Swap: Tune Required?
Superhereaux
chicks make me feel inadequate
538
South Texas
like the title says, if i had say a bone stock 98 gt and decided to swap over to pi heads, cams and intake would i NEED a tune (handheld or custom) or could i just install the new parts, fill 'er up with 91 and head out?
You don't NEED a tune, but you SHOULD get a tune. If you think about it, that's quite a change from what the ECU is used to...higher CR, more flow, you know the drill. It will help you leech out every last HP from the swap as well as making sure it's withing proper specs as far as A/F ratio is concerned.
I would get one, you'll also benefit from it too. Im doing the swap this spring with VT stg 1 cams and will be getting a tune. Im hoping for 300rwhp:D
Good luck with that :D
I decided not to do the swap. The cars mileage was getting higher, and higher, so I decided to sell it, get the cobra, and get something for a daily driver.
Just so you know, there will be a very noticable increase, but not killer.
just realized that i didnt answer the original question.. no you dont NEED a tune.. but its a good idea whenever you do a major mod.. i drove on my PI heads for about 10,000 miles before i got an SCT tune
