  • SN95 4.6L Mustang Tech
PI?
  • Thread starter Thread starter Zach_Mattison
  • Start date Start date Jul 1, 2008
Z
Zach_Mattison
9
Lincoln NE
Jul 1, 2008
  • Jul 1, 2008
Does PI stand for something
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jul 1, 2008
  • Jul 1, 2008
like pi heads? performance improved
Z
Zach_Mattison
9
Lincoln NE
Jul 1, 2008
  • Jul 1, 2008
oh ok so if i'm looking for pi headers and cams whats beter like the shorties or the long tubes?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 1, 2008
  • Jul 1, 2008
Hi Zach...
Generally PI relates to the 99+ cars heads and upper intake. They were redesigned and were an improvement over the original 4.6 heads found in the 96-98 cars. The older heads/intake is referred to as NPI for non performance improved.
98COBRA281
1,348
30
59
Jul 1, 2008
  • Jul 1, 2008
pi headers, long tubes dominate shorties, that why i decided to go with them, shorties are worthless on 4.6's
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 1, 2008
  • Jul 1, 2008
Long tubes for the more power...generally about 5-8 over the shorties. Cams depends on what the car will be used for. A daily driver would be best with a mild cam that would give you the bump in HP without driveabilty issues. But cams and headers come with a pretty hefty price due to the extent of the work required to install them unless you do the work yourself of can get a good mechanic to do it on the side.
98COBRA281
1,348
30
59
Jul 1, 2008
  • Jul 1, 2008
COramprat
do you have stock manifolds? 240rwhp that great for a npi, maybe ill be able to beat that with my heads and Lt's
Z
Zach_Mattison
9
Lincoln NE
Jul 1, 2008
  • Jul 1, 2008
yeah i think everything is pretty much stock i just got the car from a dealer and it was a trade in so he only knew about the add on's you could see on the outside is there a way to tell if the heads or pi or npi just from looking at them bc who ever had this car b4 put a lot of money into it to not have done anything performance to it. it hase the really expencive exhost that comes out the side of the car and it has the roll bar add on too and i know the exhost is around $2000
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 2, 2008
  • Jul 2, 2008
I doubt the exhaust was $2k. I made my side pipe cat-back for around $320 and spintech or roush is around $600. Take a picture of the engine focusing on the front of the intake manifold, i'll tell ya what you have there.
98COBRA281
1,348
30
59
Jul 2, 2008
#10
  • Jul 2, 2008
  • #10
ill put 500$ on it, that its a stock npi....
Z
Zoie_daGT
58
#11
  • Jul 2, 2008
  • #11
PI heads stand for the heads from 99-04 mustangs. They are Power Improvement heads and have higher compression and better flow. They also came w/ a PI intake manifold, and PI cams. These are the reason why the New Edge mustangs came stock w/ 260 hp and the non PI(96-98) have 215-225.
Mustang5L5
Mod Dude
Feb 18, 2001
43,363
18,108
224
Massachusetts
Jul 2, 2008
#12
  • Jul 2, 2008
  • #12
Take some pictures of it and post it up. Take some shots under the hood and interior and under the car.
Also, would help if you told us what year it was.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
J
Used PI intake what to check for
  • jay99914
  • Oct 29, 2024
SN95 4.6L Mustang Tech Nov 4, 2024
jay99914
J
