Pics of 18" argent painted aluminum wheels
If these are the Ford option ones, there should be some in the later pages of the pictures thread above. You can also try to do a search for Fanblades as that (I think) is what they are more commonly called if we are talking about the same wheel.
Like this one right?
That's from www.mustangforums.com. They have a lot of cars posted on there with the new 18" Ford wheel options, more than here anyways.
I have the 18" Black Bullitts from FRPP I just installed last week. Will post a picture tomorrow. Ford has a wheel viewer for the 05'-07', but it's just a semi-cartoon. The 18" Bullitts do not have as large an outside rim look to them. About a 3/4" aluminum edge (no outside weights showing). The weights are installed on the backside and you can use stick-on weights closer to the front of the wheel to further balance the tires. For tires, I used Kumho Ecsta ASX 255/45/18's on mine. The tires/wheels do not go all the way to the fender lip edge. I like the look. Also, added the FRPP Springs and Swaybars w/OEM shocks/struts. Now a very firm ride, but a bit more compliat that the full FRP kit w/Moton Shocks/struts. Also, the front Antisway bar has three settings from mild to agressive antisway. Mine is in the mid setting, but may change to the "softer" setting. It is a true 1.5" drop in ride height. So far so good.
