Pictures from Vince
Rickyll7
718
So what does this tell you???
This is from the passenger side. The guy who tuned it last had the wideband on the drivers side. :shrug: Vince is going to test the injectors and the tune later today after the long tubes are done. :D Hope its an easy fix... :rolleyes:
It is common practice to run the wideband on the drivers side. The drivers side tends to run hotter and leaner due to the way the cooling system is routed.
Yea, I had a feeling that was the case. Just not sure if it could make a difference. Anyone know what might cause the lean cylinder? The injectors are new frpp 24 lb.
