pin connector cleaning help
  • Thread starter Thread starter flashback87
  • Start date Start date Aug 30, 2011
flashback87
345
Cleveland, OH
Aug 30, 2011
  • Aug 30, 2011
i have been doing a lot of research on cleaning the 10 pin connector. i saw from multiple posts that you should use electrical contact cleaner or non flammable brake part cleaner. well i went to 2 auto parts stores and all of the brake cleaner was flammable and even the electic part cleaner was flammable.
what is everyone using? i picked up some anti flammable, anti corrosive lubricating spray at radio shack. would that work?
also, when you clean them, should i just spray or should i be using some thing to wipe down?
i did as much research before hand as possible but am still confused.
Thanks for all the help
R
ryan7662
120
  • Aug 30, 2011
Just get some of this stuff from oreilly's or autozone Amazon.com: CRC QD Electrical Contact Cleaner Aerosol: Automotive. It's flammable coming straight out of the can but evaporates quickly and leaves no residue at all that could possibly ignite. Just make sure you disconnect the neg. battery cable first and you'll be just fine using the qrc cleaner. Make sure you get the kind with the picture of a connector on the front and not the taller one with the picture of a alternator on it that sh-it will eat your connectors up like sulphuric acid
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 30, 2011
  • Aug 30, 2011
The Radio Shack stuff will work fine. It's just more expensive than the other alternatives.
flashback87
345
Cleveland, OH
Aug 30, 2011
  • Aug 30, 2011
thanks guys, i guess i will just use the stuff i got at radio shack. it says it elimnates oxidation and corrosion. when i use it is leaves an oily resdiue.
is that ok?
R
ryan7662
120
  • Aug 30, 2011
You mean that DeOxit stuff they have right? I bought some DeOxit d100 cleaner and DeOxit Shield on amazon but I'm going over every connector on my 95 gt. I've replaced a lot of broken factory connectors that I could find replacements for. Some of my busted main wiring harness connectors aren't for sale anywhere now though in which case I've rewired each individual wire with it's own bullet connector.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
