ping help
  • Thread starter Thread starter FordBaby
  • Start date Start date Nov 11, 2006
F
FordBaby
14
  • Nov 11, 2006
Anyone have any kinda video or anything on wat pinging and detonation sounds like ive never heard it before and would like to kno because my car is make a funny noise and my spark plugs are white (lean?)
Jason 302
685
71
68
Newark, Ohio
Nov 11, 2006
  • Nov 11, 2006
Yes white means its lean, but tell me how you are reading them. Pinging has often been described as marbles inside a coffee can.
HISSIN50
34
129
Nov 11, 2006
  • Nov 11, 2006
Yep. It has a very metallic/glasslike sound, which is not like many other motor sounds.
F
FOXtool
12
  • Nov 11, 2006
TRY RUNNING HIGH OCTANE FUEL AND SEE IF IT GOES AWAY. OR MAYBE YOUR TIMING IS TOO FAR ADVANCED.
Mustang78
486
Aberdeen, WA
Nov 12, 2006
  • Nov 12, 2006
you mean too far retarded?? too many people get this mixed up..and it confuses the new guys horribly
~Mark~
HISSIN50
34
129
Nov 12, 2006
  • Nov 12, 2006
I have no idea what's going on but................
Too much ignition advance leads to pinging.
DJTR
228
OTTAWA, Ontario, Canada
Nov 12, 2006
  • Nov 12, 2006
High test fuel and properly timed engine is key
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 12, 2006
  • Nov 12, 2006
Pinging or spark knock is not the same as detonation.
Pinging is preignition of the fuel air charge by some source of ignition other than the spark plug. The source of the ignition can be a hot spot in the combustion chamber such as carbon, a spark plug insulator, side electrode, or a sharp edge on a valve. It occurs before the spark plug can fire and while the piston is still on its upward movement towards TDC. That is the cause of the characteristic ping or ringing sound, much like shaking a coffee can full of BB’s.
Detonation is the uncontrolled explosion of the fuel air charge after the spark plug fires and starts to burn. In a properly running engine, the spark plug ignites the fuel air charge and it burns slowly and evenly across the combustion chamber, much like a fire as it burns its way across a grassy field. When detonation occurs, the ignited fuel air charge causes an increase in the combustion chamber pressure and temperature. The remaining fuel air charge that has not been burned self–ignites explosively causing tremendous heat and pressure. The source of secondary ignition can be the same as preignition, or can be simply due to the heat and pressure. Detonation is what damages engine parts because of the excessive heat and pressure.
Pinging can lead to detonation, and the results are the same: engine damage because of the excessive heat and pressure
Pinging is caused by a number of things:
1.) Hot spots in the combustion chamber such as carbon deposits from high mileage or excessive oil consumption.
2.) Wrong heat range on the plugs.
3.) Too much initial spark advance.
4.) Too low an octane rating for the engine setup.
5.) Lean fuel mixture.
Lean fuel mixture breaks out into several sub categories:
A. Vacuum leaks
B. Air entering the intake without passing through the MAF
C. Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D. Leaking exhaust gases from EGR valve at WOT.
E. Clogged fuel injectors.
F. Fuel injector wiring problems causing injector not to deliver rated flow.​
6.) Computer problems: (computer problems are not common like sensor problems)
A. ROM has bad data in fuel or timing table. This should also set a code in the computer.
B. Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one.​
7.) EGR not opening at cruse power. The computer adds timing advance to compensate for the slower burning speed of the EGR diluted intake charge.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
  • Locked
Engine Help timing possibly
  • K1tha1
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
