  • 1994 - 1995 Specific Tech
pinging in third
  • Thread starter Thread starter donnie84
  • Start date Start date Oct 10, 2004
D
donnie84
52
  • Oct 10, 2004
i posted this on corral.net as well, just thought it would be good to post here too:
hey all, whenver i mash down the throttle on my 95 GT in third gear i start to get some pinging after 3400 rpms. sometimes it does it in the higher rpms of 4th as well...it does all this after the car has been warmed up for a bit. the car is stock, wondering what to do to get rid of it, im planning on getting a vortech and i want this to not be a problem. its cool if i have to back the timing off for a bit now, once i get the blower ill get larger injectors and a good dyno tune so it wont matter. i also havent done a tuneup in a bit, maybe newer plugs/wires/cap/rotor will help. tell me all what you think, thanks!
P
ProCharge94
20+ Year Stangneter
Aug 31, 2004
71
Jax, FL
Oct 10, 2004
  • Oct 10, 2004
Does the car run fine? you may have some spark rattle. As for the tune up, it never hurts
willys1
1,004
New Jersey
Oct 10, 2004
  • Oct 10, 2004
I used to get the same thing on the highway.I switched from Plus to 93 octane.Problem solved Have you advanced your timing at all?
91LX_5L
1,943
British Columbia
Oct 10, 2004
  • Oct 10, 2004
Probaly your timing, its probaly advanced too for (14*) and your running low grade gas. If you run higher octaine gas im sure it will fix the problem or just drop your timing down to around 12*
D
donnie84
52
  • Oct 10, 2004
im already runnin 93, before i did run 93 tho it was pinging bad. i personally havent advanced the timing, but maybe it is off? what is spark rattle (if it is this) and how can it be fixed?
91LX_5L
1,943
British Columbia
Oct 11, 2004
  • Oct 11, 2004
Yeah Id check your timing if the better fuel helped id bet its past 14, you dont need to go any higher then that for sure.
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
J
Help - SCT Woes
  • James banks
  • Jan 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 2, 2026
squeak93
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
