Here is my situation, i recently got offered a trick flow street upper and lower with 30 pound injectors, C&L meter and elbow,adjustable regulator 400 buck from a good friend so i bought it, i installed it on my car with a 3/8 trick flow spacer. With this installed i cant run 10 degrees timing cuz it pings like crazy. i know 30 pounds is big for my stock motor for now but i have plans for something better later on, I heard people running 30 pounds in a stock motor with no problems. I have heard that the c&l meter does not like a cold air intake elbow i have tried rotating the meter to see if it helps and no luck. i replaced 02 sensors, IAT sensor and ECT sensor cuz i heard those might cause the pinging. NO luck with those either. the fuel pressure is set up at 38 psi with vacuum and 40 without. Anybody think that i should buy a pro m instead since i want to ad a blower later on or should the c&l meter work. I also run 91 octane and still pings, Any help would be appreciated this
pinging is driving me nuts!!!!!!!!!!!!
). you can get so much more for so much less with the 5.0s.
