  • 1994 - 1995 Specific Tech
pinging
  • Thread starter Thread starter gtstang86
  • Start date Start date Sep 17, 2007
gtstang86
55
California
Sep 17, 2007
  • Sep 17, 2007
hey guys,
my car is pinging under when i accelerate. it gets worse the harder i accelerate and doesnt start until after 3000rpm in forth gear. it cant be the octane grade because itll do it with 91 octane(highest in CA). any ideas on what could be the cause?
gtstang86
55
California
Sep 17, 2007
  • Sep 17, 2007
i also bumped the timing up from the stock 10 to 12.
95BLKGT5.0
608
Auburn Washington
Sep 17, 2007
  • Sep 17, 2007
First do a search on pinging there are tons of threads on it.
Second Change your timing back to 10.
Third Clean your MAF real good.
Forth check your fuel pressure.
9
94v6GT
141
  • Sep 17, 2007
i know some people had o back theirs to 8* to stop pinging while on 92.
HISSIN50
34
129
Sep 17, 2007
  • Sep 17, 2007
YOu might also be running out of fuel. 4th gear, high RPM and accelerating creates the largest burden on the fuel system. If you can have a friend watch FP while this occurs, that could be helpful......
Good luck.
Dino Dino Bambino
1,673
90
79
Cyprus
Sep 18, 2007
  • Sep 18, 2007
gtstang86 said:
hey guys,
What mods do you have? If you have several, maybe the fuel pump's maxed out at higher revs and unable to keep up with the demand, causing the engine to run lean. The stock fuel pump only puts out a maximum of 88lph or 145lb/hr (that's ~18lb/hr for each injector). If you assume a BSFC of ~0.5, that means it'll only feed ~290 or so crank HP.
The timing could be the problem so return it back to 10*BTDC as the first measure.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
