Pinion Angle Question
most lowering kits don't effect pinion angle too much. You really only need to worry about it if it is going to be drastic. when lowering a car you gotta also worry about the yoke bottoming out on the transmission when the suspension is active. (like a shock bottoming out while driving). It was a big issue when I used to help out my buddies raise trucks. As for little 1.5"-2.0" lowering you really don't need to worry about it. the angle doesn't change enough to cause binding issues.
thanks, i think im going to check mine though i have a wobble in my drivetrain somewhere and pinion angle and new/ ballanced rear tires are the only things i have not changed
as far as i know it wears out U joints prematurely, can bottom out the yoke in the tranny(already mentioned stuff), and on lifted trucks it will starve the front bearing of oil if the angle is too high, also you want the tranny to axle angle to be as close to straight as possible, even if that means tipping the motor down in the back a little, this is mostly for drag racing but the straighter the U joints/driveline the less HP lost through the movement of the U joints..
~Mark~
Having the pinion angle set improperly will wear u-joints out faster like Mustang78 mentioned.
It will also affect the way your car 60ft's at the track or on the street... there are different recommended starting points depending on whether you have stock, urethane, or solid bushings, with solids needing the least amount of negative angle because they flex the least
The idea is to have the pinion and driveshaft lined up when the car is under acceleration..
