pinion angle.
  • Thread starter Thread starter tylerrocks
  • Start date Start date Jul 13, 2006
T
tylerrocks
514
Big Spring, TX
Jul 13, 2006
  • Jul 13, 2006
I am getting ready to build a 9" rear end for my car now that the motor is complete. I am having a housing shortened from an F-150, I will buy the centersection and axles new. What I need to know is if there is any good writeups (or advise) about measuring and setting pinion angle, as well as the specs. I would like to weld my spring perches as close as possible to the correct angle.
10secgoal
2,801
San Diego
Jul 13, 2006
  • Jul 13, 2006
I don't know of any wrieups, but it's pretty simple. It's in relation to your crank.Find the angle your crank is at, what ever it is, setup your rear from that. MIne was something like ten, and I set it at -2.5
67FBack
316
New Braunfels, TX
Jul 13, 2006
  • Jul 13, 2006
I have heard that any angle over 6% is going to cause premature U Joint wear.
66Runt
680
Jul 14, 2006
  • Jul 14, 2006
The stock angle is 3 degrees
Check you engine/driveline angle by first getting your car level, referenced off the rocker panels. Check both rockers to make sure you don't have a "frame twist". If your engine/driveline angle is at or less than 4 degrees, and this is the combination you are going to stay with, then go ahead and match the perches to this angle. If you think you might change later, my suggestion would be to weld the perches at the 3* stock angle.
If the engine/driveline angle is greater than 4 degrees, I'd suggest correcting this first.
From my experience, car drivelines start to get vibrations above 4 degrees. I've also had vibrations start when the difference in the two angles reaches between 1/4 and 1/2 degree. Your experience may differ. I've had very good results staying between 3 and 4 degrees, and matching the angles to less than 1/4 degree difference. I use a jeweled movement inclinometer (for building model airplanes). It is very accurate, and was cheaper than the professional tools. The down side is you have to be careful not to damage it.
HTH,
Scott
thehueypilot
1,084
Medina,Tennessee
Jul 14, 2006
  • Jul 14, 2006
http://www.baselinesuspensions.com/info/pinionangle.htm
G
gsxrken
206
Weschester County, NY
Jul 14, 2006
  • Jul 14, 2006
With due respect, I would ignore that link entirely. Try this thread for how you want to setup a vintage mustang.
http://forums.stangnet.com/showthread.php?t=471744
66Runt
680
Jul 15, 2006
  • Jul 15, 2006
I like the first article link
This one
http://www.drivetrain.com/driveline_angle_problem.html
I didn't care for the second one. cheap inclinometers from Sears, Home depot etc can be off by as much as 1/2*. In my opinion they don't have a smooth enough movement to give good repeatable results closer than 1/4*.
I picked up jeweled movement incidence meter used in building remote control airplanes. It is wicked acurate and about $30.00. It also comes with a nice long beam usable to level the car using the rockers as your guide. This is a good option if you are only doing one rear end, or are careful handling it (I've had this last one for almost 8 years).
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
