pinion bearing preload
  • Thread starter Thread starter fast94mustangGT
  • Start date Start date Sep 18, 2008
fast94mustangGT
60
  • Sep 18, 2008
Ok, so im putting together my rear-axle. Did research on the web, found a site with a 8.8 rebuild right up. it says new bearings get 24-28 in/lbs, old bearings to 10-14 in/lbs, which seems backwards to me. Also says with ford gears you can reuse the stock pinon shim. Well pinon is meshing at the heel of the ring gear(think its the heel, outer diameter of the ring gear). I have preload sat at 25 in/lbs, is that right? Everywhere i look on the web tells me something different. Did i preload it to much and pull the gear down to much? Or am i going to have to reshim the pinon?? Any help will be appricated.
Aryan15
236
CA
Sep 18, 2008
  • Sep 18, 2008
Are you using the marking compound?
fast94mustangGT
60
  • Sep 18, 2008
yea, using gear marking compound. but i can't get the mesh pattern right without having crazy backlash. and once i got the back lash down to .009 the mesh pattern is way out, the ring gear is riding more towards the top of the pinon gear.
Aryan15
236
CA
Sep 19, 2008
  • Sep 19, 2008
What ratio did you have and what did you switch to?
EMW150
2,020
Roaring Spring,PA
Sep 19, 2008
  • Sep 19, 2008
The new pinion bearing preload spec should be a little tighter like you posted because they loosen up a bit in a short time. As far as being off on the pinion depth, did you use the same shim under the pinion? All the FMS gears I've ever had were fine with the shim that came out under the origional pinion bearing. That's not to say it doesn't happen. What is the backlash where you're seeing a good pattern? If it's out of range, you need to check to make sure the pinion bearing is pressed on tight to the gear or you may need to reshim the pinion.
fast94mustangGT
60
  • Sep 19, 2008
I had 2.73 and im changing to 3.55.
With the stock shim under the pinon bearing, Which was a .032" shim, i wasnt getting the mesh pattern i want with .016" of backlash. With backlash at .008 the pinon was meshing way to much towards the heel of the ring gear today i stepped it up to .035" and it helped but still wasnt happy with the mesh pattern and i had it down to .009 backlash, and when i went to press the bearing back off i bent the roller carrier. But im pretty sure ive got to down now, this is my first axle build so i kinda learnin. Thanks for the Help guys!
Kinda nice to post on Stangnet again, been hangin out at FBF here latley.
1987stangman
684
24
  • Sep 21, 2008
What write up was it? I used the MHD (Master housing demesions method) I also went from 2:73 to 3:55. Using the MHD method I even reused the carier shims and backlash was right in spec.
BTW: It is hard to remember, but I don't think the stock pinion shim was 035", it thought it was smaller. Been awhile though
fast94mustangGT
60
  • Sep 21, 2008
I used this right up...
http://http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm
I got the mesh and backlash to a point where i was happy last night, had to use a crazy amout of pinon shim though, .039" worth of shim. The car does have over 200,000 miles though. But once its in im gonna take it for a quick spin just to see if i hear anything funny. Thanks for the help guys
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Starters suck. So does the aftermarket!
  • Blue Thunder
  • Apr 30, 2024
5K
1974 - 1978 Mustang II Talk & Tech May 13, 2024
Blue Thunder
M
  • mnky99
  • Sep 5, 2025
mnky99
M
