pinion depth gauge
  • Thread starter Thread starter 88mustng
  • Start date Start date Nov 20, 2004
88mustng
76
NJ
Nov 20, 2004
  • Nov 20, 2004
where is the cheapest place to get one?? would it be cheaper to just bring my car somewhere to get it put in.
and yes my stepdad was a ford mechanic so we defs know how to do it.
anyone know where to get one??
if im even calling it the right thing i dont know
thanks
steve
HISSIN50
34
129
Nov 20, 2004
  • Nov 20, 2004
some use a dial indicator and magnetic base. have you asked your stepdad - he might have the tools to get the job done?
good luck.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 20, 2004
  • Nov 20, 2004
If he's helping you with it, I guess I'd ask him; if he has the background you say, he'll know where you can put your hands on one better than we will.
While I understand the basics of how to set a rear end up, I always pay someone that has done it a bunch of times to do mine. I don't have the tools needed (presses/pullers for bearing removal) to do the job.
rd
3,316
63
109
Ocean Springs MS
Nov 20, 2004
  • Nov 20, 2004
Summit sells a tool by Proform, that includes the dial indicator, the jigs, and the extensions, for about a $100. In their catalog and on their website.
I just finished doing one the hard way. I cut a piece of aluminum angle and made holes to bolt in on the differential cap bolt holes in the case, and a hole over the pinion head. Had the face of the angle surfaced at a machine shop that does heads, to make it flat. I used a dial caliper, the extension end, to measure through the hole to the pinion head, and subtracted the angle thickness.
That gives the axle/differential centerline to pinion head depth. Took four tries, pressing the inner pinion bearing on and off, but it is within .002 by my measurements.I put the stock differential shims back in, and have .008 in backlash.
The contact pattern looks ok, maybe a bit too toe oriented.
I am going to sleep on it and see if I think it is ok, or maybe subtract a couple thousanths of pinion shim and try again.
It helps that I have a homemade case spreader that bolts to the differential case bolt holes, so I do not have to hammer the differential shims back in. That would be the most difficult part to me, especially with the aftermarket stackable shim packs.
I will probably buy the tool soon, just because, after three of these, I want to do it a bit easier.
I
Idwitheld-1`
335
Portland Oregon
Nov 20, 2004
  • Nov 20, 2004
I have seen this tool and by all accounts I would expect it to be quite expensive (over a grand).
rd
3,316
63
109
Ocean Springs MS
Nov 21, 2004
  • Nov 21, 2004
I made the case spreader from a piece of 1/2 in plate I found in the middle of the road, a turn buckle, and a piece of angle. I laid out some c shaped pieces to fit over the diff cap bolts, with enough space for the diff bearings to clear and go into the case, two straight pieces for the spreader. At that time I did not have a torch, so I paid someone $35 to cut the pieces. I bought a turnbuckle, some 4 inch long, half inch bolts, and made pipe spacers for the bolts. I drilled the holes at home. It fit my 7.5 in axles, and fits 8.8's also. It is somewhat cumbersome to put on and take off, and the 8.8 bearings don't fit through it like the 7.5 did, but it has been well worth it. Just got done using it a half hour ago.
If you use the stock differential shims and lots of care, you can tap them back in, as lots of people do this. If you use the stackable shims, it is hard to tap them without damaging them.
Actually, crushing the crush sleeve was more difficult than anything, took a half in breaker bar and a 2 ft pipe extension.
But the gears are in there!!!!
sn9550
1,184
Charles Town, WV
Nov 21, 2004
  • Nov 21, 2004
Don't waste your money on the Proform piece of junk! You'd be better off with out it. It is very poorly manufactured.
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
