AdRock
When my bolt broke it did the same thing as yours. The threads that you see left are pretty much all the threads on the bolt. Have you tried sticking a magnet in there to see if the rest comes out? I know, obvious question, but I have to ask.
I'd tend to go a little overboard sometimes, but I'd drop the whole rear-end to get it away from the car and access the job a lot easier. Center punch the bolt and drill you a pilot hole in it. Start your E-Z out and then back it out. Heat the piece of bolt up with a propane torch (why I'd remove the rear-end) and then get your E-Z out back in there. Tap on the E-Z out to keep a good bite. Good luck with that man.
) is only on the first 4 or so threads nearest the head of the bolt. This should mean that the threads remaining in the casing are not held in with any locktite and when the first piece of the bolt is removed, there's no torque on the piece stuck inside.
