Pinion snubber removal
  • Thread starter Thread starter habiv
  • Start date Start date Aug 3, 2006
H
habiv
125
  • Aug 3, 2006
Okay, so I have figured out where this thing is located, but how do you remove it? Do you have to go under the seat or something? Thanks.
stangjunkie
381
  • Aug 3, 2006
??the pinion snubber is located just above the diff to the front a bit, it is being held on by 3 8mm hex head bolts one on either side and one in front
just swapped this out when i did my springs last night
H
habiv
125
  • Aug 3, 2006
The new pinion snubber I got with my springs has one bolt going through the middle. Do I need to drill a new hole? the new one looks exactly like the one at the top of this page:
http://www.stangsuspension.com/store/comersus_searchitem.asp?strSearch=pinion+snubber&curPage=2
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 3, 2006
  • Aug 3, 2006
A little OT, but I keep Mouse Poison in the Garage for the Winter, when I pulled my Snubber down it was full of all the Pellets, I dont even know how in the hell those little suckers got up and into the damn thing.
J
jmd2914
937
Napa, California
Aug 3, 2006
  • Aug 3, 2006
im curious about the same thing, i have one of the bbk snubbers, how do i put it on?
H
habiv
125
  • Aug 3, 2006
I just went under the car and figured it out. There is a bracket that bolts to the car right above the diff. and the snubber is bolted to the bracket. There are three 8MM bolts, like stangjunkie said, that secure the bracket to the car. Take the bracket off and then you will be able to remove the snubber from the bracket and put the new snubber on. It's very easy, took me 10 min.
Stangjunkie, do you have any pics of the car with the new suspension? What springs did you use?
J
jmd2914
937
Napa, California
Aug 3, 2006
  • Aug 3, 2006
the one from bbk i have i think is adjustable ( not sure) how far down will it go?
H
habiv
125
  • Aug 3, 2006
I'm not sure about the adjustable but the one I just put on my car that came with my springs sits about 3/4 of an inch away from the diff.
D
Rust on Window Belt
  • DuluthFoxbody
  • Nov 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 4, 2026
DuluthFoxbody
D
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
R
Help finding where this ground goes on the L head
  • RubberDuckUsb
  • Sep 11, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 11, 2026
RubberDuckUsb
R
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
