I need to hook my MSD switched power lead to a connection that has power in both 'on' and 'start'. The only real easiest way I hear to do this is to tap into the positive coil lead where it taps into the ignition switch. Before I start cutting wires I want to make sure I'm tapping into the right spot. Now the coil wire is red with green stripe right?
Also the pink resistor wire limits the voltage to the old coil to like 6-7 volts. What I'm sort of unclear on is where the pink wire begins/ends and where the coil wire begins/ends? Does the pink wire go directly in the ignition switch? When I look under my dash I can see both, but I can't really see all to well so some tips on doing this would be greatly appreciated. Any good drawings or pictures?
Thanks
Thanks
