Blue Thunder
I like falcons,(2door) cougars and torinos even more than the early 'Stangs. Especially the cougars, they look killer. There's a car that's about as uncommon on the highway as a II.
I owned a 1978 Mercury Bobcat and it was a great car. I bought it for $50.00.It actually passed the safety check. I proceded to drive it for a year with no problems. After putting a new 351M into my 1976 Cougar XR7 the Bobcat got parked. Rebel (sometimes posts here) ended up pulling it all apart to fix his wounded 1982ish Mercury Capri. Anywho a pre 74 Pinto/Bobcat has very little if nothing interchangeable with a II. 1974-1981 Pinto's had nearly identical front suspensions. The Pinto never had the rubber bushed "toilet seat" that mounts the strut rods and trans cross member. It sounds minimal, but a Pinto/Bobcat will rip your hands off going down a bumpy road! The steering rack manual/power is the same. The brake system is all the same. The seats are differnt but will bolt in. None of the body panels are interchangeable. None of the glass is interchangeable.The rear leafs are shorter in a Pinto. If the Pinto/Bobcat has an 8" it will be the same. The 2.8l and 2.3l engine and trans combos are all the same as a II. The front bumper will fit. So will the rear if you trim it. (It looks stupid because the pinto bumper has a space to bolt a plate to, so you end up with two plate mounts).
Yep, and you can tell them that until you are blue in the face and they always come back with "accept your car sucks" kind of reply.CobraIILover said:Most cars are usually based off others. This is true for Mustangs of all years.
First Gens were built on the Falcon platform
MIIs were on the Pinto platform
Foxes were built off the Fairmont platform
SN95 was a modifed Fox so it also reverts back to Fairmont platform
The 05 Mustang is built on the Linclon LS/T-bird/S-type platform
The kicker with the II, is that most people have it backwards. It was a Pinto based design, but the chassis and suspension was totally redesigned in 74 for the Mustang II. The Pinto then shared that new setup. The previous year Pintos are not similar to the MII.
I really think that the Pinto referance came from the base model, steel wheel, no spoilers fastback II. This version of the II just looks WAY too much like a Pinto.
1badII said:That would be a nice cruiser.
Eos said:Yep, and you can tell them that until you are blue in the face and they always come back with "accept your car sucks" kind of reply.![]()
innocentfool said:and will a little bit of mods a 460cid engine will fit!!!!!!!
chromehorse11 said:My first engine swap was in a Bobcat. I took out a tired 2.3 (warped head) and shoved in a 302. "Shoved in" being the operative phrase. It was pretty much a hack job, but what do you expect from a 14 year old!!! That thing would bolt like you wouldn't believe, and the best part was that unless you popped the hood, or looked underneath, you wouldn't have a clue a V8 was lurking under there. Aaaahh those were the days!![]()
Eos said:I have never seen a bobcat, pics?
Eos said:NO! Theres no connection! "runs out crying"
78pinto said:Wow........that hurts.....
78pinto,
Your pinto kicks so much ass that there is no need to say anything![]()
You have a rocking car that will blow away 99.9% of the cars on the road and be proud of it! Just FYI, the first car I even rebuilt was a 68 Dodge Dart that was Pea GreenLet me tell you, all my friends laughed at me when I was building it but they had no problem riding in it when we were doing 110 down the highway
So, some say run away from a pinto, but I say run away from conformity!![]()
Chad
Addicted_2_II said:78pinto said:Wow........that hurts.....
78pinto,
Chad
Amen brother! Thanks for the nod!![]()
Blue Thunder said:
kinda a cute... little fella..Blue Thunder said:The bobcat actually had a V8 option, too. I saw one prowling around town here a few years ago.
Edit: I'm only fairly certain it had a V8 option.
Eos said:kinda a cute... little fella..
chromehorse11 said:I don't think that a V8 was optional for the Pinto/Bobcat. I think the biggest engine available from the factory was the 2.8l. And i think that was even pretty rare. (possibly reserved for the wagons, cruiser wagons)
