Alright, here goes. First of all, my specs:
Basically unmodded '02 GT Coupe.
Stock Speakers/Stock Amps w/wiring harness
Pioneer AVIC-N1 head unit
Two questions:
1.) I'm trying to hook my XBox up to it (or a PS2 or GameCube) and I've been able to connect the RCAs to the hideaway unit without problem. I bought a power inverter rated at approximately 140 watts, 110 volt. Plugged the XBox (and GameCube) into the inverter, which was plugged into my cigarette lighter. They both powered fine, but the screen had annoying lines on it and the speakers crackled. This occurred whether the vehicle was on or off. I tried a higher wattage inverter, same problem.
So, on a whim, I got a huge extension cable and plugged the XBox/GameCube into my house outlet and eliminated the inverter entirely. Bingo, life's good. My question? What's the problem with the inverter? Voltage? Connection? Wattage (doubtful)? How do I get power to this thing that isn't going to cause the flicker/speaker fuzz. This is driving me insane, and I'm sick of ripping my dash apart to run wires, so I'd love to know what's causing this problem once and for all.
2.) Not sure how much anyone knows about the AVIC-N1 but when I go to 3D Calibration mode in the Navigation section, I get a Speed Pulse of 1 or 0 (which I think should be your actual speed) and my Learning Status is "Simple Hybrid". From what I can gather, this means that my Vehicle Speed Sensor wire isn't attached properly. I'm not sure that's the case, but I have a suspicion that it is. If this is the case, where is that wire located, and does a novice (like myself) have a snowballs chance in hell of hooking it up properly? I've heard the wire isn't entirely necessary but will significantly aid map generation and GPS.
Thanks a BILLION for any replies,
James
Two questions:
James
! I must say that I am fully impressed with the new head unit ! There was no problems with the intall into the Mach 460 and the sound quality is great.
