I am finding out that I don't know jack about pipe threads and fittings, so hopefully someone can lend some insight into this. How do I figure out what size I need for the following applications?
Problem 1: I am trying to find a fitting that screws into the fuel pump and gives me a nipple to run a 3/8" fuel line (hose) to the carb. (Ditching the old steel line) I found one at Napa that looks just like the old fitting on the steel line, but it won't thread in.
Problem 2: I need a T fitting on the oil pressure extension so I can run the stock guage/sender and an aftermarket mechanical guage.
Problem 3: I can't get the old heater hose fitting out of the old manifold, and the only one I can find is a 2.5" tall monstrosity that looks horrible. What size is this fitting?
Can you usually find these things in the plumbing section at your local Ace/Lowes/Home Despot?
What else do I need to know? (NPS/NPT?)
Should I use some kind of pipe dope?
NRC ? Ok let us in on your build up secret..............................
We going for a Nuke supercharger or somethin here?
