  • 1994 - 1995 Specific Tech
Piston and heat
  • Thread starter Thread starter moosetang408w
  • Start date Start date Jul 26, 2005
moosetang408w
90
Alberta, Canada
Jul 26, 2005
  • Jul 26, 2005
I was wondering if polishing the tops of your pistons help with reflecting heat. I wanted to know how try this is because heat not put into the piston is energy for a little bit more power but more importantly expansion of the piston and rings. If it helps even a bit I want to do it before I install them back into the engine.
194stang
148
  • Jul 26, 2005
It might help a little for a short time. A street driven car will carbon up the pistons pretty quick I would think. I have seen thermal coatings you can have applied that are supposed to do just that. No idea how expensive it is though.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 26, 2005
  • Jul 26, 2005
I have seen some say that polishing or cleaning the tops of pistons while they are in the motor can allow some of that carbon and other material to fall down into the ring grooves which can cause probs.
Later
Grady
94CobraPace
907
Houston, Tx.
Jul 26, 2005
  • Jul 26, 2005
If you are that worried about heat, then get the pistons coated.
Joes95GT
3,132
Delaware
Jul 26, 2005
  • Jul 26, 2005
Way back in the day (i.e. Grady's era ), guys used to polish the tops of pistons. They could never find if it helped or not.
My contention is this....
If the polished top reflects heat, that heat is still in the chamber even if it is "reflected". Where is it going to go?
Joe
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 26, 2005
  • Jul 26, 2005
I was thinking that if you are gonna do that, what about polishing the chamber in the head?
Later
Grady
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 26, 2005
  • Jul 26, 2005
The only thing polishing the pistons will do is lessen the buildup of carbon.
Heat will still be transfered through because iron sucks up heat like no tomorrow.
Changing to aluminum pistons would be a great way of reducing heat, as aluminum is a great conductor of heat.
Scott
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Axleback installation
  • Bob Foos
  • Jun 13, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
N
New Edge 3.8L Forged Internals
  • NtheGAME
  • Jun 1, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 3, 2025
