  • SN95 4.6L Mustang Tech
piston dont go in
  • Thread starter Thread starter emjajr
  • Start date Start date Dec 15, 2003
E
emjajr
  • Dec 15, 2003
some body know if is someting else so the piston go in
on the rear brake i am twisting and the piston don go in
D
DC-GT
312
  • Dec 15, 2003
I am guessing that you are changing brake pads or something? If so you might need to take the cap off of the master brake cylinder reservoir so it can let the back pressure out. Hope that helps!
Bo
E
emjajr
  • Dec 15, 2003
tanks. i will tray
E
emjajr
  • Dec 15, 2003
yes Iam changing the brake pads
And i removed the cap from the master cylinder
and i dont know how much i,m supposed to turn so the piston
goes back in. or is there something i need to do?
D
DC-GT
312
  • Dec 15, 2003
First off, try calling the ford dealer and ask a service man about if it even needs turned in or if there is a trick to it. They usually don't mind answering questions.
Before turning it in just try using something softer than steel to push the pistons in, like a piece of wood. If that works, and you feel them bottom out, then you can try turning the piston adjustment in. Don't do that unless you can't get the new pads in first though.
Hope that helps.
Bo
ken44ny
86
long island,ny
Dec 15, 2003
  • Dec 15, 2003
Hope that helps.
Bo
you need a special tool for the rears-dont push it in you'll f**k up the caliper
D
DC-GT
312
  • Dec 15, 2003
That is why I suggested calling the dealer first. Things change too much to keep up with for someone that is not a fulltime mechanic. Please call the dealer to make sure.
What does the tool do to help move the caliper?
Bo
XTONKAX
619
UT
Dec 15, 2003
  • Dec 15, 2003
I responded to your other post. Oops.
There is a special tool with two notches that will fit into the piston and turn it while going in. It's an absolute must to have. Emjajr, where are you? Is there an AutoZone nearby that you can borrow the tool from? They require a deposit, but it's reimbursed when you take it back.
W
Wi-Stanger
111
Wisconsin
Dec 15, 2003
  • Dec 15, 2003
You can also use a needle nose pliers, it can be a SOB to turn in though. Just get the pliers in good and keep turning to the right. It's not too hard.
GOLDENPONY
1,503
LOVELAND, OHIO
Dec 15, 2003
#10
  • Dec 15, 2003
  • #10
Piston
I think you should open the bleed screw then twist and the piston should go in.
A
S197 2 piston front caliper dimensions
  • AussieDavid
  • Mar 26, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 26, 2026
AussieDavid
A
9
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 5 6 7
2K
Classic Mustang Specific Tech Today at 4:26 PM
horse sence
Interest in a bracket to mount 13 cobra disc and calliper on 68 disc brake spindle
  • My68gt500kr
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 21, 2026
My68gt500kr
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
