Piston question
  • Thread starter Thread starter seijirou
  • Start date Start date Feb 19, 2006
seijirou
2,417
DFW
Feb 19, 2006
  • Feb 19, 2006
What is the compression height of a stock late 80's 302 piston? Did it vary in the foxbody years?
Rick 91GT
Mustang Master
95
99
PA
Feb 19, 2006
  • Feb 19, 2006
Didn't vary as far as I know 1.600"
seijirou
2,417
DFW
Feb 19, 2006
  • Feb 19, 2006
Okay, this may sound like a silly question. But If I were to install normal flat top pistons with a 1.645" compression height that would put them an additional .045" "in the hole" at TDC, increase valve clearance and drop compression right?
seijirou
2,417
DFW
Feb 19, 2006
  • Feb 19, 2006
Another question. From what I understand, stock pin diameter is .927". I'm looking at some pistons with a pin diameter of .9122". Would it be recommended that I install larger pins in the new pistons so I can run the current rods. Or get rods with a smaller bore for the smaller pin diameter.
This would be with the 1.645" compression height pistons. Is that going to give me enough meat to punch out the pistons for a bigger pin?
Rick 91GT
Mustang Master
95
99
PA
Feb 19, 2006
  • Feb 19, 2006
First the taller CH put the pistons out of the bore way to far, so they will not work at all. Depending on what brand piston they are you could mill them but it may take too much meat off the crown.
Second, you should buy the piston with the correct pin size for your rod, or change rods....
What are your exactly are you trying to do? There are many off the shelf parts that will work with the stock crank.
seijirou
2,417
DFW
Feb 19, 2006
  • Feb 19, 2006
Yeah I just realized I was thinking about that backwards.
I'm putting some 2v 351c heads on a 302. The primary issue I'm concerned with right now is P/V clearance. I was thinking about using the 351c pistons but you're right, they're not going to work unless I get a shorter rod (and i don't like short rods) or maybe a 289 crank. (which I think basically bolts in) The 351c has a smaller piston pin diameter than the 302. I might be able to use 302 boss pistons, but i'm not sure what the measurements on those are. And they're going to be hard to find.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
A
S197 2 piston front caliper dimensions
  • AussieDavid
  • Mar 26, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 26, 2026
AussieDavid
A
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
03 Mustang, found dinged pistons, pics.
  • 2003 mustang gt modded
  • Aug 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 19, 2025
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
