Piston to head clearance??
  • Thread starter Thread starter backfocus
  • Start date Start date Mar 30, 2011
backfocus
254
Little Rock, AR
Mar 30, 2011
  • Mar 30, 2011
I am looking at buying a slightly used short block that has twisted wedge cut pistons (dished). I will be keeping my current TFS High Port Heads which are not twisted wedge ( I was using cut flat tops). Does anyone know if the piston to head clearance will work with the two different styles? Or do I need to look for new pistons and get the setup rebalanced?
Rick 91GT
Mustang Master
95
99
PA
Mar 31, 2011
  • Mar 31, 2011
Mike what is the exact set-up..... Are the piston dual relief or just the Twisted Wedge design??
The piston to head clearance "aka quench area" will be fine, but you may have piston to VALVE clearance issues which will require new pistons. Since your using a highport I assume its a healty set-up and you dont want to skimp on the cam profile just to make the set-up work.
backfocus
254
Little Rock, AR
Mar 31, 2011
  • Mar 31, 2011
It looks like the pistons are dual relief Rick. They are Probe dished pistons (14.2cc). The short block is a 327 in a Dart Sportsman block.
I had my heads reworked this last year and had planned on putting them back on my stock block. But with my turbo plans, I am looking at different options as I fear I will be near the block limit. This is just going to be a weekend driver / show car, but I do plan to take it out on the strip on occasion with our car club.
As far as the setup, it would be the short block with the Kauffman/TFS heads. I have talked with you about these heads before, when I was trying to find out more about them, since they were made back in the early 90s. I have a GT40 ported lower and a the GT40 upper. I know the intake will be a hold back, but I like the look of it for the show car aspect and I would like more torque than horsepower. The cam will most likely be a customs by FTI. I am still working on the turbo, I have called Hellion a few times and have talked with them about something custom. I would be looking at only running 5 to 8 psi for the street setup.
I think just getting new pistons will probably be the best route.
Rick 91GT
Mustang Master
95
99
PA
Mar 31, 2011
  • Mar 31, 2011
Let me do a little digging for more info, I think I can help ya
stro270
  • Apr 1, 2011
Stick a thin layer of modeling clay on the top of one of the pistons bolt the head on push rods etc roll theengine over slowly by hand. remove the head and you will be able to see if you have the valve clearance needed..
backfocus
254
Little Rock, AR
Apr 1, 2011
  • Apr 1, 2011
Thanks stro270, but I know how to do that and that is not what I asked. As I said I am looking at a slightly used block, which means it is not in my possession. The block has dished twisted wedge pistons and I don't have Twisted Wedge heads. I was just wondering is anyone had used dished twisted wedge pistons on a standard style head? Minding the fact the I have High Port heads.
Just needing to get a better idea about if I bought the motor how much more I would be spending to make it work for me.
backfocus
254
Little Rock, AR
Apr 4, 2011
  • Apr 4, 2011
ttt
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
