Ok, thanks! Reason I'm asking is that according to the book "How to tune & modify your Ford 5.0-liter Mustang" by Steve Turner, it says regarding cylinder heads "stepping up to the 2.02 intake valves mandates moving to aftermarket pistons notched for proper valve clearance; this is easily accomodated at rebuild time..." I was a bit surprised to read this as I thought most aftermarket heads even with 2.02 valves were basically bolt-on.
I havent decided on heads yet but the AFR 185 is one I'm considering, hence just wanted to check with you people.
