pistons
302kid
29
i have a stock 95 302 shortblock..can i run an after market piston without doing a 306 or 331 and stuff i just wanna put a set of pistons in and raise the compression a tad bit.. wat should i do.. advice?
If the bores are still round with no defects or taper, you could hone it and install new pistons.
It will cost a lot of money (balancing, new rings and bearings, assembly, pressing them off and on the rods, etc) for a little gain, id suggest milling the heads as well
