Pitman Arm Install
  • Thread starter Thread starter Gunslinger66
  • Start date Start date Mar 26, 2006
Gunslinger66
  • Mar 26, 2006
O.k. This is my first post in stangnet. I 've researched a lot, but I still need some guidance from the gurus. I have installed a new flaming river manual steering box on my 66. The problem now is the ptiman arm going back on the new box. The box is in place. I've centered the steering wheel from left to right and slid on the pitman arm. The arm is close to the steering linkage, so I am assuming the pitman arm is in the right orientation. The pitman arm won't tighten up to the box. I've tried heat (maybe not enough). What to do what to do...
Thanks in advance for you help.
BigDaddyCee
1,404
Canada
Mar 26, 2006
  • Mar 26, 2006
I don't have the Flaming river box but I do have stock manual steering on my 65. The Pitman arm should be keyed and only go on one way. If I were sitting in the drivers seat it would hook left. Then you would put the lock washer and nut on and torque it to spec. I don't think it is necessarily meant to be tight to the box? Because when you want to take it off in the future, you will need to get the jaws of a puller in there to remove it.
J
66 Fastback with 302 stroker. I have center link Borgeson issues Please advise
  • Joe Johnston
  • Sep 16, 2024
1965 - 1973 Classic Mustangs -General/Talk- Sep 17, 2024
Joe Johnston
J
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
