i have heard that platnum is no good for the turbo motors. my buddy swears they are better than my ngks can anyone clear this up for us
) if i try and run the higher boost with the 93 it starts detonating about halfway through 3 but with the cam 2 and a little tweak of the timing it runs like a skalded dog. i know the boost levels are sketchy with my setup but i have a new motor on the stand so im kinda guinea pigging this motor if you know what i meen. the plug question cam about when we were talkin about puttin a nitrous system on it and he bought autolite double platnum athat are like 2 heat ranges colder than stockRED LX
20 PSI is not doable on 93 octane. Simple math.
9 to 1 , which is what most 2.3 have, and 20 psi is like 14.5- 15 to 1 in a NA engine and 93 octane will not support a 14 or 15 to 1 engine no matter what people say they have done or know someone who has done. Feeding a bunch more of 93 octane fuel into a engine that needs 120 octane will just blow the engine. Because the fuel will self detonate at around 10.5 compression ratio. So if you would feed 93 fuel in a 14 to 1 engine the mixture would ignite about 50 degrees before the piston was at the top, You can see how this would not be good.
2.3 don't have a stronger crank assembly than the 2.5 or any other stock 4 cylinder. What it takes is a STEEL crank, canferred bearings and a strong oil pump. none of which the 2.3 has.
If I remember right the Turbo 2.3 mustangs were not any faster than the stock 302 GT, (which were an embarrassment) and the turbo’s were making around 3-5 psi.
20 psi in a engine with a cast iron crank and cast pistons will not work, No matter how or who says it will.
Biff
I would guess I have been building cars for longer than you, but that's a guess.
My first engine build was in 1962.
...blah...blah...blah...blah....
I think I'm done with this topic, I really don't care about 1/2 motor performance anyway.
