Platinum Spark Plugs
  • Thread starter Thread starter wild70stang
  • Start date Start date Feb 6, 2006
wild70stang
317
  • Feb 6, 2006
Platinum spark plugs are supposed to dissipate heat quickly to prevent detination. Although a too cold of a spark plug you will not attain proper running temperature and thus your engine will not run. Where am I getting with this question you might ask? Well I have heard of platinum spark plugs that are made for stock engines without causing problems such as fouling. So what kind of brand and name of any platinum spark plugs will run on a stock engine without fouling? Or is this just a big waste of money for a stock engine?
Great68
691
Victoria BC
Feb 6, 2006
  • Feb 6, 2006
Probably the biggest advantage to platinum plugs is that their long life.
At one time I ran bosch platinums in my Mustang, my old Toyota, my Honda, I've never really noticed any sort of performance improvements or deficiencies.
Swede958
712
Austin, TX
Feb 7, 2006
  • Feb 7, 2006
I wouldn't run platinum plugs in anything unless specified. As far as I know the performance gains (if any) are nill. I noticed a big difference when I switched off the POs bosch platinums to regular motorcrafts.
If you do decide to throw in a platinum plug, I'd try the autolite first (should be #APXX). THose seem to be the most domestic friendly platinums besides OEM called for stuff (i.e. Motorcraft and AC delco)
4MuscleMachines
417
South Texas
Feb 7, 2006
  • Feb 7, 2006
The only plugs that have made a difference to me where the Rapid Fire plugs by Autolite on a carbed engine. The engine felt more responsive and with better idle quality. A minor change that I noticed but my wife would probably not have. I changed my other car to the Autolites thinking the other car only peformed better because of worn plugs, but I still noticed an improvement.
rbohm
6,698
550
204
tucson,az
Feb 7, 2006
  • Feb 7, 2006
for the most part, you wont find any real improvement just by swapping plugs. depending on your combination, you might find 1/2-1 1/2hp if you spend the time on a dyno running a variety of plugs through the motor, and change plug gaps to find the optimum gap. you might pick up another 2-3hp by indexing the plugs. platinum plugs will last longer, but the tips run hotter increasing the likely hood of detonation. as far as running hotter or colder plugs, if you decide to use a platinum plug, run one that is one heat range colder. when talking about hot or cold plugs, that is just the ability of the plugs to disapate heat. you do need to match the heat range to the engine combination you are running, but you can move up or down one or two heat ranges as needed to prevent plug loading, or detonation.
HistoricMustang
2,359
Confederate States of America
Feb 7, 2006
  • Feb 7, 2006
BOSCH
HistoricMustang
www.historicmustang.com
wild70stang
317
  • Feb 7, 2006
Thanks for the advise rbohm, but I already knew about cold/hot plugs like 3 years ago . I currently have regular autolight spark plugs, and just wanted to see if there was anything better. Also, my plugs are gaped at 35( I was told by a Napa guy). SO THANKS GUYS!
dawtips
56
  • Feb 7, 2006
just uhh, make sure your spark plug wires can handle the new charge or your engine may catch on fire, like mine did
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
R
Dead car, please don't ignore
  • RogerMV
  • Apr 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 16, 2025
