  • 1994 - 1995 Specific Tech
please help! clutch problems
  • Thread starter Thread starter Daniel50
  • Start date Start date Aug 27, 2006
Daniel50
716
Discovery Bay, CA
Aug 27, 2006
  • Aug 27, 2006
i was at the track and went to shift into 4th and clutch pedal goes straight to the floor. car wont go into gear. then drive the car home without using the clutch. car makes funning squeaking noise when the clutch isnt engaged. then if i slam down on the clutch pedal the clutch engages. and can drive like normal. car sit overnight and go to drive it down the street. squeeling goes away. all of a sudden car wont move until the very top on the pedal than slips like crazy. any ideas?
Blackened302
1,439
South TX
Aug 27, 2006
  • Aug 27, 2006
maybe your clutch cable is going out and/or stretching?
94-302-vert
1,947
NE CT
Aug 28, 2006
  • Aug 28, 2006
I would guess it is the TOB.
Daniel50
716
Discovery Bay, CA
Aug 28, 2006
  • Aug 28, 2006
any other guesses
droptopford 5 0
427
Aug 29, 2006
  • Aug 29, 2006
it could be a few things, but it sounds like either the throw out bearing, or the clutch fork where it meets the throw out bearing since it catches when you slam on the pedal it seems like either one of the two are not ligning up correctly.it could also be the cable, or maybe the self adjusting stock quad if you still have that... that might be broken/ slipping/ catching at wierd times to cause the clutch to slip and/ or never disengage... those pieces are known to break at the track all the time
Daniel50
716
Discovery Bay, CA
Aug 29, 2006
  • Aug 29, 2006
i bought a king cobra clutch kit and a ram pilot bearing hopefully this will fix the problem
droptopford 5 0
427
Oct 3, 2006
  • Oct 3, 2006
did that fix the problem? if you havnt installed the t/o bearing yet, i think ive heard that ford makes the best t/o bearing and others have a tendancy to squeek... but dont quote me on that, maybe others can chime in on that
T
Mcleod Hydraulic Clutch
  • TheJay806
  • Apr 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2025
limp
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Warm car no clutch ???
  • mac_55
  • Sep 30, 2024
  • Other Auto Tech
Other Auto Tech Sep 30, 2024
C
1992 LX 2,3, automatic problems, oil dissapears.
  • Carpimp
  • Aug 10, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Aug 10, 2025
General karthief
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
