Please help! Door (pushbutton) latch assembly
  • Thread starter Thread starter grantur01
  • Start date Start date Jun 22, 2004
grantur01
226
Dayton, OH
Jun 22, 2004
  • Jun 22, 2004
A few days ago the latch got stuck up for the push button(door latch) on the drivers side. Well I have taken the door panel off tonight but it was getting too dark for me to see well. For those of you that know. There is the rod that is connected to the door lock itself. There is another rod that connects to the latch inside the door for the push button latch (outside). That rod isn't connected to anything. It looks like there is a hole that the bottom of the rod attatches to. Its on the same piece that the bottom of the rod for the door lock is on. That piece doesn't lift up far enough for me to attatch the rod for the push button latch in the hole(for the hook at the bottom of the rod?? How in the #@%@!!!!!!! Someone please help me. Is there somthing missing???? All i see is that the rod is hooked at the end and it is supposed to slip into that hole on the same piece that the door lock rod is also hooked into??? Or am i wrong???
I really apologize for the vague description. I hope someone that has run into this problem will be able to make sence out of my ramblings. Thanks!!!
grantur01
226
Dayton, OH
Jun 23, 2004
  • Jun 23, 2004
bump, sorry
65 fastback
1,347
Northern VA
Jun 23, 2004
  • Jun 23, 2004
I have my door panels off and can check for you, but I'm having a hard time understanding your problem. Can you repost what you need checked?
I might even be able to shoot a couple of pics for you.
Tim
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jun 23, 2004
  • Jun 23, 2004
Can't help with the rod but on my 67 the latch stuck open and the door would not latch. It turned out there is a spring to pull the latch shut which I found in one of my many catalogues. It was a real p.i.t.a. to attach; really long needle nose pliers, a flashlight, and a cut up arm were involved. It would pay for you to order the assembly manual. I've got one for my 67 and scanned the pic into my computer, blew it up, cleared it up, and then I could see what I needed to do.
grantur01
226
Dayton, OH
Jun 23, 2004
  • Jun 23, 2004
I'm sorry guys for my vague description. I really need a digital camera to take pics. It would be easy then!!!
Ok inside ur door. There are two rods that run pretty much the length of the door. One Rod is connected to the locks(inside for unlocking/locking door). The other rod is attatched to a latch that ur push button(on the handle, on the outside of the door, to open the door) is attatched.
Picture this, your outside of your car and you want to open the door to get in. The push button pushes all the way in with no "catch" feel(meaning the door isn't unlatching). So the door won't open. So you pull the panel to see inside the door and see that the rod that is ultimately attatched to the latch of the push button is not connected to anything at the bottom of the rod. Now looking at the other rod that is connected to your door locks/stems, is hooked at the bottom of the rod.
I stuck a mirror inside the door to see that there is a hole that a hook would go into(same unit as the door locks rod is hooked into). MUSTANGDAVE, you bring up a good point... maybe I'm missing a spring that will attatch to the hook at the bottom of the rod and then hook into the pivot piece(towards the bottom of the door)
I looked at the Haynes. I doesn't explain anything!!
I appreciate your help guys!! really! let me know if u need anything!
G
GaPonyFarm
663
Columbus, GA
Jun 23, 2004
  • Jun 23, 2004
Sounds to me like you lost the retainer for the rod from the pushbutton. Its probably sitting in the bottom of the door. You're right the rod does go to the latch mechanism. You might be well advised to order the Body Assembly Manual. Its a pretty complex thing to describe. You might be better off to remove the door latch assembly to see better where it goes.
grantur01
226
Dayton, OH
Jun 23, 2004
  • Jun 23, 2004
thanks for the reply! Where can I find the Body Assembly Manual??? I've heard this a couple times now in the past few days. thanks again
G
GaPonyFarm
663
Columbus, GA
Jun 23, 2004
  • Jun 23, 2004
I know for sure that Mustangs Unlimited sell them. About $25.00 IIRC. You might also want to order the Electrical, Interior, & Chassis assembly manuals also. There is a also the Ford Shop Manual. These are all excellant resources, if you plan on working on your own car, or plan on keeping it for a while. A great investment.
65 fastback
1,347
Northern VA
Jun 24, 2004
  • Jun 24, 2004
The rod that attaches to the lock tumbler (exterior door handle) attaches below the other rod that you see. It sounds like the retainer clip is broken or missing.
In the picture you can see both rods, the one to the left runs up to the lock tumbler.
MrBobMarley
460
Ft Myers, FL
Jun 24, 2004
#10
  • Jun 24, 2004
  • #10
My retainer clip was sitting on the bottom of my door a week after I got the car. Put it on and door worked again.
G
GaPonyFarm
663
Columbus, GA
Jun 24, 2004
#11
  • Jun 24, 2004
  • #11
What are the odds that somebody would have that pic.... You just saved somebody alot of work, 65 Fastback!
grantur01
226
Dayton, OH
Jun 24, 2004
#12
  • Jun 24, 2004
  • #12
You are the man 65FASTBACK!!!
That was the perfect help! Well it makes more since now. There is nothing at the bottom of my door though. I looked last night and couldn't find that retainer clip or whatever it is anywhere. Looks like I'll have to order it then... along with some assembly manuals.
REally thanks so much for the help!!!!
Cobain03
996
Lexington, Ky
Jun 24, 2004
#13
  • Jun 24, 2004
  • #13
hey not to be smart but i bought a shop manuel and it has everything for it in there i mean evertything it has really help me
65 fastback
1,347
Northern VA
Jun 25, 2004
#14
  • Jun 25, 2004
  • #14
Important Note!
I have been working on my door locks, too, lately. I ordered some retainer clips. There were two choices: plastic clips - $1.50 ea and "Like original" clips - $4.95 ea. Well, I got the plastic clips - total POS - I couldn't get them to work for S!. Long story short, I reordered the "like original" clips - worked great, major improvement.
Get the like original clips, I got mine from VA Mustang. Also, go ahead and order a couple of extras, just incase.
Good luck,
Tim
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Parking brake cable
  • 78 Mach1
  • Apr 21, 2025
1974 - 1978 Mustang II Talk & Tech Apr 30, 2025
78 Mach1
