I just recently have had my motor rebuilt 69' 302. It originally had a three bolt dampner on it. They installed a new dampner, but it is a four bolt. I have spent almost two months looking for the right pulleys, and i can't afford the march pulley setup. Because i couldn't afford to have the engine balanced could i replace the four bolt balancer they put on to an original three bolt dampner. IF i do this will it cause problems with the balance of everything.?.
I have checked the junk yard several times, the only pulleys i can find that line up is a water pump pulley that is barely larger than the shaft with two grooves. And a crank pulley with three grooves and is ginormous. This is how awkward they are, the first groove on the wp actually straddles the second groove on the crank..
