Please help I need to fix ASAP
  • Thread starter Thread starter 90VertGT
  • Start date Start date Nov 1, 2004
90VertGT
159
MA
Nov 1, 2004
  • Nov 1, 2004
Hi guys,
My car had a Walbro340 put in it about 2 weeks ago. Yesterday my car started doing funny things and I am lost. When I start it up the idle bounces up and down and then dies. When I put it in gear it does the same. The car is fine while driving but once I let the RPMs get around 1500 or lower it starts hesitating and when I brake it stalls. Any idea what this could be? I don't even know where to start. TIA.
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Nov 1, 2004
  • Nov 1, 2004
Look at vacuum. Check the brake master cyl. I have had that big hose pop off and fug up the car totally. Start there. Then give more info and maybe we can help more.
Rockin302
236
California
Nov 1, 2004
  • Nov 1, 2004
I agree with 4dStang, also check and see for wear/cracks along the hoses.
Would a loose gas cap do that or even drive belt tension??
HISSIN50
34
129
Nov 1, 2004
  • Nov 1, 2004
generally a vac leak will make the car idle higher, not lower. also the idle will return slowly from higher rpms.
a stockish motor should pull 15-20" at idle.
have you pulled codes yet? even if the CEL is not on, a code could be in the KAM. could be anything from the IAC or TPS being out of whack to a leaky EGR valve.
good luck.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
