Ok,
I have a 93 Mustang GT. I have bought every god damn thing i can buy and am going krazy. I posted this before but maybe someone that had the same problems can help me now.
This is how it all started:
I had the car running very low on gas until it shut off do to no gas. I whent and put about 10+ gallons and it wouldnt start. I would turn the ignition key on and the fuel pump would prime but it wont shut after a few seconds like it should, it would just keep going and going as long as the ignition key was on, just like if it had no gas on the tank. So, i put some gas on the intake and it started for a few seconds. Its ovious the injectors are not opening up.
I got spark, I got fuel pressure in the rails but no gas is going past the injectors. The injectors are getting power (tested with testlight)
Changed TFI module, cap/rotor, wires, fuel pump, fuel filter, fuel pump relay, ecu relay, inertia switch is good. There is another fuse next to my fuel relay that i dont know what it is ???
it looks just like the fuel pump relay and its right next to it.
How can i make my injectors open again so my car can get gas and start ?
Can anyone help me out
Thanks in advanced!
it looks just like the fuel pump relay and its right next to it.How can i make my injectors open again so my car can get gas and start ?
Thanks in advanced!
