Please help me track down loose ends for scratch built 74 Bronco
bcmbcmbcm
Jan 29, 2003
455
:shrug::lol::shrug::lol:
Hey everyone!
I am working on a scratch build project. Coast 306 and Lentech AOD with EFI into a 74 Bronco. I have always been a Mustang guy and a member of this board so would you please help me with some hardware questions? I am trying to put the engine in on a weekend, so I need to have everything lined up!
Need:
Hardware to connect torque converter to flex plate
EGR blockoff plate (it is a BBK EGR plate, but I wont be using EGR!)
Water pump (need reverse rotation but for a ’74 bronco timing cover, not a late model mustang!)
Something like this maybe? But from Summit? I already have a gift card there I need to use
B.C. Broncos - Early Bronco Water Pumps - products new home - reverse flow waterpump passenger outlet
Water pump studs (please provide quantity of each length.)
Motor mount to frame nuts (need size)
Transmission (87 AOD) to bellhousing bolts and nuts
Crossmember to frame bolts and nuts
All hardware to connect transmission to motor mount and motor mount to crossmember
Air filter to connect to stock mass airflow meter/elbow
B.C. Broncos - Early Bronco EFI Fuel Parts and Kits - B. C. Broncos llc - products new home - Air filter EFI
Transmission to transfer case bolts and nuts (t case is a Dana 20. Need size and quantity of everything_
Oil pump to block hardware (please provide quantity of each length.)
Thanks again everyone
