Please Help Newbie
  • Thread starter Thread starter wildstang87
  • Start date Start date Jun 15, 2005
W
wildstang87
96
  • Jun 15, 2005
hey guys, i have a million questions but right now i will stick with the important ones. i have an 87 gt 5.0 5speed. my first question is my speedo gear is yellow so whats my rear gear, 2.73?? next, the ignition switch on my column gets very hot, so hot it smokes. it has started to melt the connector that goes into it. im scared its going to burn up my car. what should i look at, loose connection, bad ground, or the switch itself being bad??? lastly, whats the best cam for a my setup, i have mac unequeal headers, cai, o/r hpipe, and 40 series flowmasters, smog pump delete, other than that its stock, speed density setup. PLEASE HELP ME.
R
Retro10
42
  • Jun 15, 2005
I can answer the one...your iginition switch is probably bad...There was a recall on those switches. If you dont want to deal with that they are like 15 or 16 dollars. When replacing make sure you check your melted wires for any problems that might arise later on...
W
wildstang87
96
  • Jun 15, 2005
thank you, that was my main concern right this minute. if anyone else knows which gear i have with the yellow speedo gear, and which cam to go with please let me know.
W
wildstang87
96
  • Jun 15, 2005
cmon, i know someone knows, please help. any suggestions.
HISSIN50
34
129
Jun 15, 2005
  • Jun 15, 2005
I would check the DS:wheel revolution ratio to ensure you know what gears you have - someone might not have used the proper speedo gear. It is sort of a definitive way of knowing, rather than deductive.
Good luck.
P
Project89
94
Panama City, Florida
Jun 15, 2005
  • Jun 15, 2005
Don't go off of the color of that spedo or drive gear to determine your rear gear ie: some people change rear gears w/out swapping in the correct spedo gear. Besides I do not think a yellow spedo gear exists although yellow drive gears do.To determine your rear gear look at the sticker inside your drivers door jam, find the code that says AX the letter below AX tells you what gear came in it from the factory. I believe M is for the 2.73's, don't know about the others. Try searching gears I have seen those codes before in here.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 15, 2005
  • Jun 15, 2005
Yup, if your car is stock (and you know if for a fact) you can use the door label...
then go to www.muntanggt.org and can help you decode your car for you. It's lots of fun!
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 15, 2005
  • Jun 15, 2005
Unless someone swapped in a different set of gears you probably have 2.73's. Most 87-93 foxes cam with these. Right now I would say the best cam for your setup is the stock cam. You aren't going to notice much gain by just swapping in a cam. To tell you the truth, putting in a larger cam than stock with your setup will actually hurt your performance and idle. I would suggest spending the money on putting in some 3.73 gears or save up to do a H/C/I (Heads, Cam, Intake). As for the switch, check the wiring to make sure there is no bare wire showing and replace the switch.
W
wildstang87
96
  • Jun 15, 2005
thanks, it turns out i have 3.08 gears. i will stick with the stock cam for now.
NosPony
278
Canton, Il
Jun 15, 2005
#10
  • Jun 15, 2005
  • #10
Speed density= no major mods. You really cant do H/C/I with it. Unless you have the computer reprogrammed. Which kind of sucks. Dont get a cam until u do H/C/I.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jun 15, 2005
#11
  • Jun 15, 2005
  • #11
Don't get a cam until you convert to Mass air flow. Then do what ever you want to the car until it won't idle anymore
HISSIN50
34
129
Jun 15, 2005
#12
  • Jun 15, 2005
  • #12
when combos are carefully chosen, one can get away with a decent amount with a SD actually.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
Electrical Going crazy trying to identify burnt and disconnected wires 83 GLX5.0
  • x_man586
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
AeroCoupe
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
