  • SN95 V6 Mustang Tech
Please help - Oil leaking into bell housing
  • Thread starter Thread starter wingnutduner
  • Start date Start date Feb 28, 2023
  • Tags Tags
    bell housing full of oil oil leak
First Prev 2 of 2
manicmechanic007
5 Year Member
Sep 26, 2017
2,545
720
143
Roy, Utah
Nov 18, 2023
#21
  • Nov 18, 2023
  • #21
Flywheel is not able to be put on backwards. The bolts only line up one way. Get a dial indicator on a magnetic base and check the crank runout yourself. Check the rear main bearings for excess clearance (loose). No new block that might be missing a galley plug right? Oil pan gasket leaking bad enough will also get into the bellhousing area. It's difficult, but pressurize the oil pan air and see if any air comes out the back of the oil pan. That will check your rear main too. You will burn up a rear main if the crank was not undersized and you install a repair sleeve. Chev makes special oversized seals for the crankshafts that need a sleeve. Inspect the sleeve you installed closely for being installed all the way. Check with the parts store you bought the sleeve from. See if they have an oversized seal for your your engine using a sleeve. Pull rear main seal out (again) do both radial and lateral runout measurements with the dial indicator you get. Inspect the seal you pull out for damage, lip seal condition and garter spring location if it has one. There are a few types of rear main Teflon, rubber, etc. Use an orange or black Ford seal. You got a zipper on that momo now. Good luck
W
wingnutduner
California
Nov 20, 2023
#22
  • Nov 20, 2023
  • #22
I'm going to redo the motor AGAIN, replacing the crank. A few people have suggested bent, dropped by the machine shop, crank. Thinking of going to the 4.2 cranks from the f150. Same block and rods from what I read. Probably need new pistons. These have l
, literally, 8 hours of run time on them.
Can anyone recommend a good source for a 3.8 or 4.2 crank?
First Prev 2 of 2
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Wednesday at 10:17 PM
AlexM556
A
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
