Suspension PLEASE HELP power steering rack install
AbhorrentSpecies
198
25
38
36
Las Vegas
So I just finished up installing a new rack and pinion. Everything seemed fine until I went to turn the steering wheel before hooking up the tie rod ends. The steering shaft inside the car is making a horrible knocking sound when turning back and forth. This is an 89 with no airbag. Could the tag joint just not be seated all the way? Or did I mess something else up possibly? Like something in the steering wheel itself.??? Idk
  • Sponsors(?)
7991LXnSHO
wanna catch the space herp
7,115
2,928
194
Kearney, NE
Check the rag joint connection since your life depends on it. Then make sure you have clearance around it and the steering shaft while an assistant turns the wheel. I think an installation error on the rack is more likely than messing up the column, but with an assistant, I hope you can tell where the noise is from.
Reactions: 1 user
