Please Help, Question about 96 GT
  • Thread starter Thread starter mattzhawk
  • Start date Start date Apr 25, 2008
M
mattzhawk
  • Apr 25, 2008
My wife has a 96 gt, the intake cracked around the heater hose on the rear of intake. I installed a new oem intake as well as new plugs and wires. My problem is #2 cylinder is dead. it is missing and backfiring through the intake, when i unplug #2 plug wire or injector wire the backfiring stops and it does not change the way that it runs what so ever. she said it never overheated(never got out of the normal zone). i checked the compression and compression is good on all cylinders (145psi on cylinder 2) so i swaped the fuel injectors around with another cylinder and the same thing #2 is dead. you can hold the throttle down above 3600 rpm and the backfiring stops but it still has the misfire. so i took the manifold back off thinking the gasket did not seal, everthing was good head was good and clean and o-ring looked good so i torqued it back down to 18ftlbs and got everything back together and same thing. So i sprayed some throttle body cleaner around the seal on the intake and no changes. I also put the old spark plugs back in and same thing, no changes. The car ran good prior to the intake cracking, i am bumfuzzled i have checked all the vacuum lines and everything and still no luck. I also rechecked the firing order to make sure i did not get a plug wire crossed and voltage to fuel injector is 13.2v, i removed the plug and the plug is covered in carbon. the rest are clean but #2 is black. coil pack is also good, spark jumps over to bracket when plug wire is removed. Can someone please give me an idea what it could be?????? Thanks, Matt
D
darkside03gt
851
Sacramento CA
Apr 25, 2008
  • Apr 25, 2008
the only thing I can think of is there may be something wrong with the coil pack. try swaping them and see if the problem follows over to the other cylinder.
you may have valvtrain issues also maybe one of the followers is messed up. IDK.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 25, 2008
  • Apr 25, 2008
96 has wires, not packs. My guess is the plug wire is wet/corroded and causing the backfire/miss.
M
mattzhawk
  • Apr 25, 2008
thanks all, my next test is to put old intake back on for a few mintues and see if the miss stops(may be problem with intake???) and maybe pull valve cover and check cam lobes and followers to see if problem is there
D
darkside03gt
851
Sacramento CA
Apr 26, 2008
  • Apr 26, 2008
Take a look at a npi gt and tell me what those things are on the front corners of the engine just above the valve covers. hmmmm they look like coil packs to me. And no i wasnt talking about cops.
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
