Hello,
I’m trying to improve the worn suspension on a ’94 GT with approximately 150k miles. I’d like to keep the geometry the same and replace the bushings as well as shocks, struts, and possibly springs. Car’s a daily driver, only been to the track to see others run, but I wouldn’t mind tightening up the suspension, even if it means feeling those potholes and road irregularities even more so. “Bang for the buck” is my motto, so yes, cost is a factor.
1. Ok, bushings will likely be polyurethane, but which ones should I replace and/or what’s the best kit out there for accomplishing the above-mentioned objective?
2. Shocks and struts have seen better days, so I’d like opinions on decent upgrades. I prefer they don’t be adjustable for simplicity sake. Are there options for replacing the “rear axle drive vibration dampers” (term straight out of the service manual) or do I simply replace them with the same part number?
3. Lastly, springs, I don’t care to lower the car but realize springs may be matched to shocks and struts, so, what’s recommended for “sportier than factory” yet cost effective? Will running the original springs work against my plan to tighten things up or will new shocks and struts already make a big difference.
I don’t have caster/camber plates and prefer to do without them, if absolutely not necessary. When I got the car, I had chain type shop try to align it twice unsuccessfully, but then got my refund and found a smaller shop who did an excellent job that’s never needed further adjustment (and I would notice if it needed it). If you think it would be to my advantage to get them, then please feel free to recommend brand/models.
Thank you all for any helpful feedback!
MG-70
MG-70
