Please Help, Tranny Install Problem
  • Thread starter Thread starter JT87NAT
  • Start date Start date May 21, 2005
J
JT87NAT
30
  • May 21, 2005
Whats up, my friend and I just replaced the clutch in his 88 Mustang Gt, the problem is we can get the tranny into the relase/throwout bearing but can't get the splines to line up with the clutch splines and push them together so the tranny and bellhousing are flush against each other, there is about a 1-2 inch gap between the tranny and bellhousing. We put the driveshaft back in and started turning the output shaft but still can't get it to slide in all the way. Anyone have and tricks or tips to help this go smooth? Could the clutch have gotten knocked a little when we tried the first time? If it did get knocked should I just take off the bellhousing, loosen the pressure plate and use the clutch alignment tool again? Thanks.
M
macx
228
SE Missouri near Cape Girardeau
May 21, 2005
  • May 21, 2005
That's probly your best bet.
Also check your throwout bushing/bearing to make sure it's not interfering.
slow93
406
  • May 21, 2005
yeah youre prolly off just a hair on your alignment not allowing the input shaft to slide into the bearing( or bushing whichever you have).i would think pull it back out and use the alignment tool and youll be ok
J
JB66
565
New York
May 21, 2005
  • May 21, 2005
Do the clutch plate and tranny input shaft have the same number of splines?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 21, 2005
  • May 21, 2005
Push the clutch pedal all the way in while another person pushes the tranny in. Good luck.
J
JT87NAT
30
  • May 21, 2005
I was wondering if that would help, btw the clutch cable came off the pedal, how does it attach to the pedal, I looked real quick but couldn't see how it attaches.
86T-Top
553
Dublin, PA
May 22, 2005
  • May 22, 2005
The cable hooks into the pedal via the clutch quadrent. As for the tranny not sitting flush with the bellhousing, this is normal. As Tunedin302 said, hook you clutch cable back up and have someone push the clutch pedal all the way down. When the pedal is all the way down, you should be able to get the tranny to sit flush.
Mario
J
JT87NAT
30
  • May 22, 2005
Mario
Thanks alot guys, all the writeups I have seen don't say anything about pushing the clutch pedal down...but I do see how the throwout bearing could keep the tranny from going all the way in if it is not pushed forward at all. Is the clutch quadrant plastic...is it attached to the very back top of the clutch pedal?
Ourobos
260
May 22, 2005
  • May 22, 2005
Yes to both your last quetions, and it is a ****** to get to. Pressing the clutch in is the easiest answer also... Good luck.
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
