Long story short, my McLaren has been in the body shop for 4 months after being hit, and FINALLY today it was ready to go. THEN, when they tried to reconnect the battery, the alarm started going off, so then he tried to start the car to turn off the alarm, but it didn't work, so he disconnected the battery ( I think at this point he said it continued to crank). As it is now, we took out the remotesrter system and checked in the ignition columnand even disconnected the ignition harness from inside the column, and even with the kill switch on and off it will still crank as soon as you touch the negative cable to the terminal. The starter solenoid is new and the car was even starting fine all the way up until yesterday. The guy took apart everything he did yesterday to check the wires and they're all ok.
Can ANYONE tell me where I should start?
Basically the owner of the shop is a d!@k, and says it's ultimately my problem, so I just want to take the car back myself and try to fix it myself.
Any help would be MORE appreciated than you would EVER know...
thanks guys,
Jeremy
thanks guys,
Jeremy
. Give it to someone else and it's just more time, more money. I need to be proactive and take every measure in my power to get his done NOW.
