So I purchased a 347 stroker kit.. so as soon as that arrives I am dropping it off at my shop.. they have verified that the block is good... so they are just waiting for the kit now.. because they want it on hand before they start the machining.. anyways... before they actually install the kit.. they are going to balance it.. but I told them that I am getting a new harmonic balancer and flywheel... so I do have a little time because they have to do the prep work on the block, boring, etc. But could you guys maybe help me with my choice of balancer and flywheel... looking at the billet steel flywheel and aluminum.. If I intend on using my stock clutch does that make a difference with the flywheel, I'm sure it does, what is stock tooth.. 157? Kinda need help 50oz or an aluminum 15lb 157 tooth flywheel. Both for manual transmissions. I plan on rebuilding my t5 for now.. Any help with this choice for the 347 would be awesome, and for the harmonic balancer.. there is 50oz and 28oz.. I know stock is 50oz, is there a benefit of one over the other... for this kit... what should I worry about.. don't want to order the wrong thing. I know its 4 bolt.. looking at fluidampr.. stock replacements are about 70 bucks, the others are about 380... any advice would be awesome... should I not use my stock flywheel and balancer... Thanks guys!!!
