  • 1994 - 1995 Specific Tech
please help with 95 gt and stalling problems
  • Thread starter Thread starter sleeper95
  • Start date Start date Jul 31, 2009
sleeper95
28
  • Jul 31, 2009
first of all i would like to thank all people on this forum for helping me with this dilemma.
The problem with my car will start if it has been sitting for quite a while, but if it has just been running and I try to restart it, it won't start. But if I let it sit for about 5 mins. after trying the 1st time, it will start up right away. Sometimes while driving it will cut off for a second or two then automatically start up again on it's own, but other times it cuts off while driving and just won't start up again.
plz diagnose this for me
Dino Dino Bambino
1,672
89
79
Cyprus
Aug 1, 2009
  • Aug 1, 2009
Sounds like the PIP sensor inside the distributor is on the way out. With the hot summer weather it's a common problem 'cause this sensor becomes very sensitive to heat soak with age. I had to change mine a couple of months ago after I experienced the same random stalling problems.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Aug 1, 2009
  • Aug 1, 2009
I had the same problem when I had corrosion under the distributor cap & rotor. When hot, there was enough resistance to stop the spark from going to the spark plugs.
TBCOBRA88
26
South Carolina
Aug 1, 2009
  • Aug 1, 2009
True that! I had the exact same problem, took me forever to figure out what it was. That is until i found my way to this awesome forum. Such great knowledgeable people here:SNSign:
sleeper95
28
  • Aug 1, 2009
for that part how much does it cost because i dont have a hole lot of money
sleeper95
28
  • Aug 1, 2009
the corrosion you found what color was it. because i looked in my distributor cap every thing was green like it was painted
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Aug 2, 2009
  • Aug 2, 2009
If the terminals are brass, then you're going to get green oxidation. If you can scratch off the green to see metal underneath, it's time for a new cap & rotor. If the green stuff is all over inside the distributor as well (not just under the cap), you may need a new distributor. Also look for fine metal shavings (gray dust), which is a sign the PIP Bullitt95 mentioned has worn out.
Try a new cap & rotor first and see if that helps.
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
