Please help with Brake Light problem
  • Thread starter Thread starter 65 fastback
  • Start date Start date Apr 12, 2006
65 fastback
1,347
Northern VA
Apr 12, 2006
  • Apr 12, 2006
I'm having a problem with my brake lights.
- Only the right side brake light lights when I step on the brakes.
- Both left and right turn signals work properly
- taillights work
Here's where it gets a little confusing - If I step on the brakes while the right turn signal is on, then the left brake light works.
Please help, I'm at a loss.
Tim
J
John Z
581
Morgantown WV
Apr 12, 2006
  • Apr 12, 2006
The wires to the brake lights run through the turn signal switch under the horn button. I'll bet you have something amiss in the turn signal switch.
t_chelle16
Keeper of the closet key
3,610
Knob Noster, Mo.
Apr 12, 2006
  • Apr 12, 2006
Yup, I bet it's your turn signal switch. I had pretty much the same problem a while back.
The turn signals work by basically canceling out the brake light.
In my case, the spring in the turn signal switch was worn out and it let the turn signal lever fall a little lower than it should. It was just enough to cancel out the brake light but not actually turn on the signal.
Try pushing up on the turn signal lever just slightly and pressing the brake. You should have brake lights.
-Chelle
65 fastback
1,347
Northern VA
Apr 13, 2006
  • Apr 13, 2006
Thanks for the replys, guys. I think you both nailed it on the head, I've traced it back to the turnsignal switch. I guess, I'll have to pull the steering wheel this weekend and see it there is an easy fix or if it needs replacing.
Thanks,
Tim
66forfun
260
Pittsburgh
Apr 13, 2006
  • Apr 13, 2006
might as well order the new switch b4 pulling it apart, they dont cost much and factory parts are still available.
65 fastback
1,347
Northern VA
May 7, 2006
  • May 7, 2006
Just a quick update to confirm everyone's opinions. I replaced the turnsignal switch with a new FORD unit (not repo) and everything works the way it is supposed to.
Thank all,
Tim
J
John Z
581
Morgantown WV
May 7, 2006
  • May 7, 2006
Thanksfor the update. I really appreciate it when the original poster has the courtesy to follow up with the solution to the problem.
66 Restomod
203
Raleigh, NC
Jan 27, 2007
  • Jan 27, 2007
Where to buy
Where can I buy a new Ford turn signal switch for my 66 for a good price?
I have already bought what I believe is a repro switch but after pulling the steering wheel off and looking around, the switch I bought does not have all the same color wires. Most are the same but a couple are off such as having an orange wire, instead of an orange wire with a blue stripe... (I want to do the replacement correctly with the best switch out there.)
Thanks for any help!
65 fastback
1,347
Northern VA
Jan 28, 2007
  • Jan 28, 2007
I got my FORD turnsignal switch from Virginia Classic Mustang - http://www.virginiaclassicmustang.com/catalog/shop/
Their website is kind of a PITA, so I would just give them a call on Monday.
Tim
66 Restomod
203
Raleigh, NC
Jan 31, 2007
#10
  • Jan 31, 2007
  • #10
Ok will do, thanks.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
