Please Help With Clutch
rattlecan96gt
106
Dallas, Texas
Ok so I have done the reading , and I have still come up with the same ending my clutch engages and disengages when the pedal damn near on the floor board I have a stage 2 xtd clutch a ford racing quadrant and an adjustable cable I have loosened the cable and tightened it all the way and in between the only difference it makes is it wont disengage if I have tightened or loosened it too much. it has resistants in the clutch it feels fine . where should I go from here ? do I really need to get a firewall adjuster ? oh and its a t45 tremec
Makes sense that if you tighten it too much it won't disengage, but you say that if you loosen it too much it also won't disengage? Did the problem just start, or have you had issues since the cable/quadrant install and was the clutch done at the same time? I personally don't like the adjustable cables. I've had two stretch and need replacing before I went with the maximum motorsport kit (cable, f/w adjuster, and quadrant). Expensive, but no problems and have never looked back.
I had it backwards in my other post, if you have it at a point where it will disengage and it's at the bottom, when loosened it won't disengage, when tightened out should disengage higher. Makes me wonder if everything is installed properly.
If you go underneath and look in the dust cover, the fork should be in a position so the tob is right off of the clutch fingers. That's where the cable should be adjusted so it sits. Have somebody press the clutch while you watch. As they start pressing, you should see it pull the fork and the tob will start pushing in the fingers.
its new but I figured out what it is I should have replaced the clutch fork also because the fingers that hold the TOB are a little shotty so it was pushing the tob at a slight angle and not getting a full "press" if you see what imsaying so I tinkered with it and held it in place then tightened the cable to the fork ..all good now shes nice and smooth
