  • SN95 4.6L Mustang Tech
Please help with codes.....
  • Thread starter Thread starter Unreal281
  • Start date Start date Mar 18, 2006
Unreal281
98
  • Mar 18, 2006
Sup, all of my mods are in my sig...i'm throwing a:
* P0420 _catalyst efficiency below threshold (bank 1)_
* P1507 _manf cntrl veh. spd. Idle Speed Control Auxilary Inputs_
codes were read at advance auto parts with a handheld device.....
what do these two codes mean?
-thanx
Pearl02
496
Kansas City
Mar 19, 2006
  • Mar 19, 2006
I think the 1507 code has to do with your IAC. Can't help you with the other code. I haven't come across that one. Pearl02.
MaxedGT
304
Surrey BC Canada
Mar 19, 2006
  • Mar 19, 2006
The p0420 is because your cat is gone, on bank 1. The other code I don't know.
It sounds like an IAC fault.
MaxedGT
304
Surrey BC Canada
Mar 19, 2006
  • Mar 19, 2006
Off topic. I just installed BBK off road x-pipe, and it sounds like I've got an exhaust leak, but I don't. If it wasn't for that, it sound great. How do you like the sound of your exhaust? Do you get the same sound, on moderate acceleration?
On topic: using mill eliminaters? The Bank one mil, is probably shot. BBk recommends switching the two mil eliminaters if it throws codes, claiming this sometimes helps.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 19, 2006
  • Mar 19, 2006
yeah your mil is probally gone. switch them.
p1507 is a IAC valve underspeed error. this is cused by the rpm's droping below what is commanded by the PCM.
the pcm has no feedback on if the IAC itself is opening right, so it can only tell if the idle speed is not what is being commanded based on IAC opening percentage.
MaxedGT
304
Surrey BC Canada
Mar 19, 2006
  • Mar 19, 2006
By switching them I mean just side to side.
Mike97gt
it doe snot
10,633
Mar 19, 2006
  • Mar 19, 2006
yeah I know what you mean. you can try it and see if the code moves to the other bank. then you know for sure the mil is bad.
and for the other code you can try cleaning the IAC valve out
Unreal281
98
  • Mar 19, 2006
Maxed......yea i LOVE the sound of mine.....have to admit it is a bit raspy but i believe you have to get used to it.....it almost makes a machine gun sound between 2500-3200....but i got used to it....mine sounds a BIT better IMO because of my long tubes.....i dunno dude...its an aquired sound basically....any other questions you got....just hit me on the AIM at unrealca281....later bro....and for the verdict....are we just saying that i need to get two bbk MILs and clean out my IAC? how do i clean that out? thanx guys...
MaxedGT
304
Surrey BC Canada
Mar 19, 2006
  • Mar 19, 2006
I think I might need time, as you say, to get used to the sound of mine. Took me a little while to get used to the cat back when I first put that on too.
As far as the mil eliminaters, try just switching them, from one side to the other and see if it still throws a cat code. If not you're good. If It does, you need new mil eliminater, or you could go with a programmer such as the Diablo preditor, or SCT.
The IAC, just take it off. spray it with throttle body cleaner and wipe it clean.
Do the same to it's port. Take off the intake duct and open the throttle and spray it down and wipe it clean inside as well.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
