Please help with main harness wiring issue!!
fastimes69
188
San Benito, Texas
I'm working on a buddies car, it's an 88 gt. He bought a Ford Racing main wiring harness and computer from 5.0 Resto to be able to use mass air. I hooked up the harness and all but there is a couple of problems. The car has two connectors in the engine by the EEC test pin, a gray and black. The new harness only has one brown connector and no connector for the black plug.The instructions say to cut the old plug off the old harness and to splice into the brown connector as per the instructions. I did that and upon cranking the pump would not come on. I wired it directly and now the pump comes on. The second problem is there is no spark or power to the coil while cranking :bang:. The computer is new and all ignition parts are new except for the coil but it was working before the work was done.Is there anything else I could check or try? Does anyone have any schematics of what those plugs are and what they control? Has anyone used this harness before successfully?Maybe I'm misinterpreting the directions?If anyone has helpful info please let me know.. Thanks....
I know this harness would work fine on 91 and up models but not a direct plug in for 88-89 cars..
I believe that the old style 87-90 was 2 plugs of 8 pins each and the new style 91-93 is one plug of 10? or 12? pins...anyway, not all of the wires are there. some of the wires are in a green square connector near the computer plug. if he was going to mass air, why didnt he just get a mass air kit, with the computer, maf, and maf wiring (it splices into your old harness at the computer)?
Alright I did this conversion in my 88 GT and it works great but it will take me a long time to write up the post to explain how to wire the plugs so the best advise i can give you is to call the help number on the bottom of the instructions and ask the guys there, they will give you every step to get it running. I forgot his name but one of the help people is a electronic guru and knows everything about our cars computers.
We tried another harness off an 89 and now there is no power to the coil, no spark either. The positive wire on the ignition coil shows no voltage when cranking. We tried my coil, distributor, new cap, wires, and rotor and still no spark. I'm stumped. Computer is new to.
I've been there already trust me ditch the harness you have and just get the MAF kit that wires in the SD harness and turn key, but do the MAF wiring while the harness is still out of the car its much easier. Good luck
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
i have the same problem except mine is a 85 carb'd...new coil and module...no spark whats so ever...it ****ing pissing me off...wiring looks old and taped up so re taped everything and still nada......
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Try checking the ignition switch and then the blue fuse link in the red/green ignition wiring.
B.) Coil
C.) TFI module
H.) Computer
Thanks Jrichker, but I have tried everything you posted already, fuel pump is coming on for sure.Injectors are pulsing as well while cranking. I've tried on items from my running car and still no luck.There is no spark from the coil. No power to the coil either. I did the screwdriver in the wire and close to metal deal but still no spark. I'm about to give up...
