Please help with alternator issue...UPDATE
Someone help please! Here's the breakdown. Went to start the 93LX and the battery was dead, I replaced it with a new battery after work. The next morning new battery was dead figured I had a short in the alternator as I've experienced in the past. Had the new battery charged and put a new alternator on. The new alternator reads 12.25V max at the battery, solenoid, and the rectifier harness at the alternator. I swap the alternator from the 92GT with the new alternator from the 93LX. The new alternator shows 14.40V at the battery on the 92GT. The alternator from the 92GT still only reads 12.25V on the 93LX.
I had a buddy from the dealership check it out this morning and the ground is good, the wiring continuity checks out. He had a spare battery so we put it in the 93LX and it showed 12.9-13.2V when revving. We think the new battery may be the culprit, he unplugs the pos lead from the batt and the car dies. He performed a couple more tests and concluded the Alt. shows bad even though it works fine on the 92GT. Now at this point the alternator on the 93LX is the one from the 92GT, not the brand new one. He said trade it for a new alt and be wary of the battery also.
At this point I am at a loss. I drove 25 miles home,checked the voltage with the car off and it's at 11.79V. The harness with BK/O, BK/O, WHT/BK is new, just put it on because my old alternator was hard wired. Could the original factory harness to the built in regulator be a problem?
Any/all suggestions are apprieciated.
UPDATE: I ran new wire and fuselinks in place of the 2 blk/o wires on the battery side of the alt and a the y/wht wire on the d-plug side. When I disconnect the terminal, the car still dies.
Here's the run down:
New alternator, new battery, new wire and fuselinks in place of blk/o and y/wht wires.
Is there any chance a short in the starter would cause this? I've had to disconnect and reconnect the battery when going to-coming home from work since this started.
Thanks for any/all help...
