Please Help!
  • Thread starter Thread starter Puntang302
  • Start date Start date Jan 7, 2004
P
Puntang302
53
Mass
Jan 7, 2004
  • Jan 7, 2004
i just insalled the bellhousing and clutch fork and throwout bearing. the teeth are not matching up, i counted 27 teeth on the yoke from the driveshaft, but 30 teeth in the driveshaft. And at the other end, the clutch only has about 10 ( i think ) teeth to slide into. PLEASE HELP! I DON'T KNOW WHAT IS GOING ON! could i have the wrong clutch? wrong tranny? anyone have any ideas?
cardudeusa
1,744
Home of the Florida Gators!
Jan 7, 2004
  • Jan 7, 2004
Im a little confused here. First how many teeth are there on the clutch? How many on the input shaft to the tranny? How many teeth are there on the output shaft on the tranny? And how many on the driveshaft yoke. And what exactly is the problem?
P
Puntang302
53
Mass
Jan 7, 2004
  • Jan 7, 2004
just called texas mustang, they sent me a TKO instead of a 3550. Thats why it was all jacked up. now i gotta get a yoke and a clutch for a TKO. Anyone got any suggestions for that?
cardudeusa
1,744
Jan 7, 2004
  • Jan 7, 2004
Isnt the TKO more expensive than the 3550? Which one did you get charged for?
P
Puntang302
53
Mass
Jan 7, 2004
  • Jan 7, 2004
was charged for the 3550, but got the TKO. Anyone know if the TKO takes the same amount of gear oil as the 3550 ( 3 bottles of syncro gear lube )?
P
Puntang302
53
Mass
Jan 7, 2004
  • Jan 7, 2004
Also will my double hump crossmember from my AOD still work with the TKO? If not what do i need?
cardudeusa
1,744
Jan 7, 2004
  • Jan 7, 2004
I think you have to have an aluminum one that has the mounting points that can move back and forth.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jan 7, 2004
  • Jan 7, 2004
Yes
Yes
cardudeusa
1,744
Jan 8, 2004
  • Jan 8, 2004
89MustangGX said:
Yes
Yes
Me and my friend installed a tko in his car. The original crossmember wouldnt bolt up to the transmission. So he had to get the one from Jegs that can move back and forth.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jan 8, 2004
#10
  • Jan 8, 2004
  • #10
AOD crossmember is already in the right spot, the T5 crossmember needs to be moved back.
P
Puntang302
53
Mass
Jan 9, 2004
#11
  • Jan 9, 2004
  • #11
thanks
cardudeusa
1,744
Jan 9, 2004
#12
  • Jan 9, 2004
  • #12
Ok thanks.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
